2012 Honda Civic Subwoofer Setup
  • 3
wolf39us
Okay so a few months back I had gotten a pair of dual 12's installed into my car. When I talked to the installer, I asked him to hook up to my "factory sub" thinking that one existed in my car.
My last car was fully aftermarket and I knew that hooking up to stock wouldn't be the same, but I decided to deal with it because I wanted to keep all of the bluetooth + iMid features.
Well the sound of the bass sounds kinda "resonating". It's almost as if there's an over emphasis on the higher bass notes and terrible emphasis on the sub-bass levels. I've been messing with the amplifier as best as I can, I tried 50hz, 75hz, 80hz, 100hz etc
Well come to find out since I have the sedan and NOT the coupe.. .no such sub exists.
Put 2+2 together and I've come to the conclusion that my amp must be getting a high boost on the mid-bass (due to the stock filter) and the lows are likely being filtered out too much making the sound is resonate?. I knew I wasn't fricken crazy!!!
My installer shook his head when I asked "did you hook up to the stock subwoofer" and he must have installed on the rear speakers. I know installing to rear speakers is definitely never the way to go when you care about your sound.
Now obviously I'm no car audio guy, but I do love good accurate sound. Am I wrong about my assessment?
I discussed this with an installer before I had my system done. He said I could keep the stock head unit with a sound processor to make sure each speaker was receiving the proper range of frequencies.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
830
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
wolf39us
wolf39us
United States
dragnix
