2020 F-150 Supercrew build
  • 1
skrsys
CarAudio.com Newbie
13
4
Illinois
I'm finally getting back into building a system after many years. I figure I'll document what I do.
Here's my truck
AMWts8CK_xUpQNWsEAKI5PBiaSTb03Ja3ogPZPpICCsteqLLUu-7fOA8UnJBqUHfvYgY3pRI75yiY9Gysncny919LAmkJRFOy1jZDP1Ne7pJIsoAHFUveJGdZ2Tqw6oiQLJ7l_5soknR_cIzxf6wYPwJr94DLQgFZpdpp1muCdWcoIQuNz38TZDAeZ4YbYsOgD9G8jQS4aPMQpjrzn5GRNXInSz4JYLR0CrlunHs5ByKMz0CRd6ZHaKGD_UB8hSmtFRMRe8G4p2kVI46bXaOkKQoEKv6ZwJFwO9bnYt9DBOzzt96k9hM8m7KE7VsUlj8gLTfCvB2nWthJbj333oggVOtIGzcF_2Ud_5vuZM6X1XpRwkEzySOWeKNFdc-Oxzf4T5rHMhD8qQS2wj8AQ_UnUlVbfaeDZMkBPfnnLU55-fTrU9xZsweo7BWaCgFWrW6jvFAAbcqmAMPfiN7XR7CIW96IvpRDg8qPACP_FviwHZ_oYYROEEqNzsN9m3gD8lsX7zWHdk5BfvxykiNFpUogB6JUjUpdERYJOLPprCoTUgTNnUoOkkQAyamWgmfPwhDiGuTBbncqsCZyh9_AcoxAE0RJwju_vHKTjVd_fNy__SEaT9Pju9hfNQpkMYSTBI1B_ViuMvgjjnwxhCVnBtABG0R0CgyAC9Jx3rcQYKI8aXVTXm8MohomRDo4Bhjb_bRpbY7CucvrBbxmeW9j82Ttg_msRaQPJP0PtgKPzLSOGHRaGk8d9zZQKitmD0QgiHgXKgb_ecJ5tst4m1bp14uqM1TC6XojnyRDVy7xQZ9ik9rKarkkajs6lF3T3gRDjJcgmGvLy4LjHoAtLwtVx3O2Du8QMUyhW59Zgtj59zu3o7jEtQJEduqUNFOxQtnmA56jbVNSsXK8MkC5QpQ3IAAbSvSs3f_nwJJr5Hz99b57LCPdf4jP6v7ZB12975DI-ha=w1291-h969-s-no
I initially wanted just a sub & amp. Then eventually, upgrade the fronts at a later date. So, I built this amp rack using acrylic and mounted it behind the seat to drive a Kicker down firing 12" loaded enclosure. I ran 1/0 OFC from the battery, and my truck has 240 amp alternator from the factory. I installed it 3/5/2023
AMWts8D9MTlMzC7g_exmyAXfqREkyaCEzemQksD3m127OZ8hsqm1P0WUv6DDMjLCdNSA0t1yyENEvGg5We_ZQh2acTWetc7XnFPCaKab_c3zmn8UAcWR5mddbZmTfA0vwefp3JCrdFO8iv1sDDk_CU5i9A3shE62DMBtVLTxd6tfMiF9slyGGaH7ljGnjD-SIY12uPefHcKT_ZGo1b_bOxSuGezMKJGMIFCy89iQoGKvEeysorbeVmW_utCeTTb8-PponFDK4G-c5sER32iRpIOi3-VtASER9D9pUggZTipdnmN4hZZEYFbx4hX6VJc-ACRvjWRd6P3ekkz2IZztOxXFQ4w3f1KIZiAkIzVsZtxEmKadAs3BL_LFxKbvPgkPmBc3yUnpwE7a3m1r-1jt48SaScYmZn9Qpu7q_t7oYOW2xvEj90-MpkOZiAsEy9dEUZiV1u9ngwbUJ_Ekfx8pV0m3773uXLK33NSFYIXQqU2fyxl4Z8gOzCPBhUXMdGv9Ap1oi8O8XO-nkNa2iaU0gv99C72XYGbqkntLNrsjzHQRUe76PjTYOWB2QILUBtsg5APf4on1XcC6rpcgJZT4biLdCVoEfdJfzNc7dW9EG4OUREZkYiogjoiL0DhwW7eDrT2LKThpVI9UF4vAFyqZYT3TcUEXS96LVinYns5AWdNA3VxXF1OGtCCvq52w7Z1OGcLgV-kz_WcOF22--s3WDz7kTvLwWNMZ_X4Jvupn6po0TLM7tDY8TCJ7BdTf5xKIzqTJYjEFkRso3DkYvdXULNplt9MunVZM4GV5QmEMeiqJ-e-XuDn96cyDdPX5tumhBAN0zZUwmshOXZjoObQYcAzymU4hBgI_kWib-kKHrYFx-5civGRpB5KNCBfnk5i3RsZpmHuANQwtBn1qSuGnhXpHAE6D3mik-Kx4JLnQb75LF8hF0Ssr2o4Wotv6O_03=w1291-h969-s-no
It actually sounded great, but then I decided not to wait on getting the fronts upgraded. So, I decided I'll move this to my other car and get a new setup for the truck. This is what I'm using for the new setup:
Custom fit F-150 Ten87 Design amp rack - 1/2" hdpe.
AudioControl DQ-61 DSP
Rockford Fosgate Punch P400x4 Punch amp (for the front & rear)
Rockford Fosgate Power T1000-1bdcp sub amp
Infinity REF-6530cx (component fronts)
Infinity REF-6532ex (coaxial rears)
Kicker L7TDF 12-inch down firing sub
Mini ANL fuse block
Relay for remote trigger
AMWts8A2yDyUZAMknksxfSerTIlhoXkEuxfqeWQQ9IO5GSrDBJhK4a2kn379oEDnRiyITIjxPKkZI5De56smIIUmnIsnHNKngvfAYBcv6CSqD7_bPZp9flYPBcyHPGllKM_auAO3dmyqDmtT_7M8dH16wwDJhrSYoS3Sx8A3umiIb09CedbK4xIO2oYUTPP13kTgdBssy_XHg2dHJPNzpNFbf4l25-v8i50wQx13YXlx_zh8uWkzmz9o7yhk4KogrCWAZbeo_AXTh1ejYT851djkmYmRFolCwGseEMQTxRmdP2kiCyeuDtcBo41I-nMdOUHoU9YHriZorQgo5HnMKS5LH1kOpm1jiL1E0pXLdSTUzBYJGuShxxr8UWR-PK3aUBGHmPN5-4PbEp_0oAO0cLs9xYnYvUSn__amsihtG7uylwZ90Drun9G0MHhsJifsXIfUWYuA12UVxwNmzhWK2IvgQDaSuO3-Fkbvcr-Ib3KhT87c4t4hkNnIoO12bs7b7utRzLYiztbZ0Udf0NF5665JBXN6udWEE0RPlvrNoAHW3FOm4az7n-n2-nmdZtjNSDcEbuRqPBNwjjzyCyGEMgW3DxOxWUO-vWoiMTOX4ylz9ibdBluR4g8Z-FjV6yeiwexP-KkkHPj3EXYZeThuE90brRRnSJ_UHkoQ14Ze5glULZs-EriNE-jO7E01k9GLiTokilSZzZqbA8EdQ2q74RgoK6d4ET0QXGGoaZYmMYERkpS9JfA7yI1vLu9vy6Ec5p8FlCdtngg5aTjA9wsX9H2AOn9RD74t_FzVAKHG0LD3pSzIcMbiVUfy2VtSWOIGC-9hztlXxpqShfpG14PxzhVZY2P9HX6UE3E9Z-r_Wlb8kIGamczZxthye-yJZAUKDGUHdMgLwuNG8XNUAde9d8BV_otNHfel3QQ0y46K0y11RhKcms7QngF1Y0IFVnUi=w1291-h969-s-no
AMWts8BDsnZCM9KUqhls16-Kh5y9v53P3vV4pAD3Ss7nNL9Ys5BC9FZC4HMQi-5LKV8hCepchOTabPA2AmNBF1b-pLBsAWnwd0b0qR6dwVlmwewnupVMoJYuMXhGbMhgcxJrYoAH5ECumY4lB3N7qPX9FZJ5HwCO8RPvjtdcOo2Es-6E1vmJMb6M97ybUpMeArSBLg0AS4BPYJh7xL3JMeGpUxpigf6-IZjbopcb5p3pDArsaDGdpMWpc_6RIW96FrIezqbwIyMVHRAEwpAiubyWuFRyEZ98NJ_3I-HIm-ol3A-q5f8fhQPKVnm1t5S44S37xWuKbnY1QJe8x1eaDB-MD0zyo7wH8MrHnkEe69wG_IJPJzgJ1rYAPvbj0d09PPta2ZrcHtKqIK6XIm3uGjGdPcl-HjGW9NjzVYV2RUA9ZeS94cbNSQfj1Nqr1dto1RfwRSi5n6SDHtrFkzx02ZvSFYk4yE6D7OywD8vSO9mbpAUkDMrlaU4wtBFpx36HLsI7bUobBhBKFV1ZTeWMZNlkOC4Jqpsov1_E4S74G4tCUgxUjLxMpHkW-C6q2AV6RekFDdvmXhCFgt-lFoX-ksOm5aC6fq4lQbb-Zg4NqDviU73TFQy9lN1yvKPUQp0NDhckNPNBxjRpG5fsRIG-WqgFD2L0C-LE4pOfbRKRw_Fs29LMgPpU0scMueHA78P-3xKWa9XPvOZourrtHHBQgrJbtqblOZWdG3BaxqGNE_WfyC4FGpAUhUKFxgl6PTdz07i7Kkk_qnA6XXi6hw25mdVVr2XBh671xNzwUxDq-Xnz_OeAyQFaTHg9n6i5AVw_QShREJ0S3W5t206MO9O11kIK2GHsVUBabch6FFc7BRG7UyDChJ6A5T8RBd9pupsVCQZtp-1r52VcgPsYETx7Rf9jnKQw-YwYDXkwoJVJE4R3JgxGMrWMj4CaPCDO9Sy4=w1291-h969-s-no
Hopefully, I'll get a chance to install it this weekend.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
Are you planning on upgrading the alternator and add extra batteries?
710
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
668
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
12
skrsys
CarAudio.com Newbie
skrsys
Illinois
skrsys
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
