2nd vehicle, new setup
  • 1
celicaboy84
I just picked myself up a 17 Honda Ridgeline and I'm already 98% on the system build. I am however coming to you guys in the sense that there's 2 things I haven't worked with in my previous build.
1) This is in the cab of a truck. I have never built a downfire setup, or ANY setup in a truck
2) I am not going for SPL this time. I want a really nice clean setup that wont rattle my dang vehicle apart
The for sure gear that's going in
Audiocontrol LC7I for factory HU integration
Image Dynamics 1400.5 amp (100x4+600x1)
ID CXS components with 3 sheets sound dampening per door
ID65 coaxes in rear. 2 sheets sound dampening per door
Now here's where the question comes in
Under the rear seat I have room for roughly .8CF sealed box
I am debating between these 2 setups.
1) a single fosgate t1 slim 10 (500 rms woofer)
2) 2 IDQS 10s (200rms each)
I'm leaning towards the 2 10's to keep the whole setup Image Dynamics, however the air space would be much more fitting for a single t1 10. I'm not saying it WON'T work for the dual setup but it's right on the lower end of recommended airspace.
Also, would 2 10s in a truck cab just be way too loud for SQ or would it be ok at 600W in a sealed box?
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
celicaboy84
celicaboy84
Kent, Wa
celicaboy84
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
