3/0 OFC Big 3 and general cables
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
3/0 (and 1/0 available) OFC wire with tin-plated (to resist corrosion) copper ring terminals, finished with an adhesive-lined (to again, resist corrosion) heat shrink tuning. These are hydraulically crimped, best transfer of power from wire, through terminal, to batt/ground/etc. that you could ask for.
Made to order, contact me for a custom quote if your order requires more than 12ft of wire.
$70 shipped for 1/0
$95 shipped for 3/0
Shipping included in the price.
I think its $95 for the whole big 3 kit but with a total of 12 ft, which is what the SHCA and All those contain like 3,3,4 right?
So $8 a foot? That doesn't add up
This is a service, not just wire, not just the supplies to do it...but to have it done, and have it done right. And, to have it done to the dimensions you want, not a predetermined length of a general Big 3 kit. If you don't need that service, then it's not for you. Also, the $8 per foot you mentioned includes ring terminals, heat shrink tubing, shipping, and my time. It's not like I'm asking $8 per foot for a 12ft length of wire.
Lugs are like $2, the 3/0 is $2-3 a foot. I can make a big 3 kit for $40 using all the same exact stuff in here, if I buy in bulk even cheaper. It's just someone who got a deal on wire and is trying to capitalize. Electron Beam has deals on 3/0 all the time for cheap. And it's also 100% copper.
Then do it yourself, no one is stopping you. A lot of people don't have to tools to do it right (hydraulic crimper, heat gun), or just want a professional looking set of cables. The lugs are $1 each, they're not cheap POS lugs. And if you can do it yourself for $40, add $12 shipping on top of that, $3 for PayPal fees...and you come out to $55 total cost to have one shipped out. I am using Electron Beam wire, 100% OFC. I'm basically doing cost of materials, times 2, plus shipping. This is a service, and it takes time to do it. This is not for the person who wants to DIY their own cables, obviously. It's also not a charity.
So you're going to turn down customers and money? You don't know much about good business practices do you
Not worth it to run out of wire early and have to make a call to order $250 more in order to get free shipping to keep my costs as low as possible, sorry. I do a lot of business, don't need any pointers from internet know-it-alls. Thanks for the concern though.
What hydro crimper you using looks nice
Just one I bought a few years ago before they got super cheap on ebay. Using AWG spec wire and AWG spec lugs makes a big difference in the crimp quality. With over-sized car audio wire, it's between 1/0 and 2/0 spec, so you have to use 2/0 lugs to get it all to fit. Down-side to that is that the wire is too loose in the lug, so you have to over-crimp it and make the lug look "winged" with flat tabs of metal on each side of your crimp. Using spec wire and spec lugs makes a perfect crimp, as seen in my original post. I'm all about quality, no short cuts.
WANTED 4 gauge OFC
These guys got it all. https://www.acdcwireandsupply.com/MTW_4_AWG_RED_MACHINE_TOOL_PRIMARY_WIRE_p/mtw-4awg-red.htm
584
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
10K
At 100 watts and such short runs, you’d have no perceivable difference between 12, 14, or 16 gauge speaker wire, OFC or CCA, nor worry about...
10
That nvx wire is good stuff...I bought a 1/0 ofc kit...it's easy to work with
19
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
