3 amps connected to OEM Nav unit in Forte Koup
  • 6
Jalum
That's a KIA!?
I'm wanting to replac my OEM cd player with the OEM Nav unit for my Koup SX. My only concern before I do this is that I'll be using a RF T400-4 and 2 RF T600-2 amps and there aren't enough RCA ouputs from the OEM nav unit to run all 3. Is there some kind of adapter or extension of some sort that I can use or would I just be SOL on keeping the OEM interior look?
Well. My problem is that the OEM Nav unit I want to put in doesn't have enough RCA connections for 3 amps. It's limited to one. So I'm looking for an answer as to whether or not there is some kind of adapter/extension for this kind of problem or if I should just deal with not being able to put in the Nav unit.
you can use 'Y Splitters' or better yet would be use a small pre-amp that you could mount in the center console or glove box
something like this
Equalizers | KICKER
Crispin is right Y split it But you might want to rethink using a factory HU, I did it for a long time in my Volvo didn't realize how much you loss doing it that why. If your taking out the original one anyways go with aftermarket. If you are set on that way than i would put something in there to clean it up. Just my opinion.
I would recomend if your gonna do this to y adapt only amps that are going to run subwoofers and use the high level inputs on the 4 ch. I could go into detail behind my reasoning but its alot of typing.
I've been looking at the 3sixty for a couple of years now and I'm sure that would do the job on making the Nav unit sound a lot cleaner. I'll probably end up getting it.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
175
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
423
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Jalum
That's a KIA!?
Jalum
Charleston, SC
Jalum
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
