3 Amps - Rockford R300X4, Rockford R400-4D, Rockford R500X1D
  • 1
randpost
//content.invisioncic.com/y282845/monthly_2018_10/IMG_20181003_173942.jpg.1cf83d3b3d5c293ad16c16d943d1df87.jpg
View Listing
Selling the three amps listed. All in excellent cosmetic and working condition. Amps saw little use before upgrading to higher wattage speakers. Throwing in the 2 sets of Maximo 6.5 COAX (4 speakers).
Local pickup only, Phoenix AZ area. $200.00 even.
Rockford Fosgate R500X1D Prime 1-Channel Class D Amplifier (no bass knob)
Rockford R300X4 Prime 4-Channel Class AB Amplifier
Rockford Fosgate R400-4D 400 Watt Full-Range Class-D 4-Channel Amplifier
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
154
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
416
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
randpost
randpost
Phoenix, Az
randpost
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
