nda03vic 10+ year member
I'm looking for an amp @ with atleast these specs...any suggestions? I have a budget of about $700...I orginally wanted to try the Audiopipe 3000 but cant find this amp ANYWHERE!
How are those amps. Any stores sell them(online stores). Have you used them? know anyone that uses them?Crescendo Audio :: Amplifers :: 3KWP Monoblock Amplifier
get this amp and run it at .5 ohm does 4000 rms and is a much better amp same as saz-3000d
Thats for their amplifiers.For those that dont know...I have 2 15" AQ HDC3's... .5 ohm voids the warranty though I believe.
moet amps can't handle it... but if it can, your subs will be a little louder and take your hearing faster...Ok...Any Negatives to running .5 ohm?
i own one its the same exact amp as saz-3000d they just warranty theirs at .5 ohm where sundown doesn't. it is a great amp looks to be built solidly, at .5 ohms it will draw more current and create more power sam negative running at 1 ohm instead of 2 ohmHow are those amps. Any stores sell them(online stores). Have you used them? know anyone that uses them?
