4 12" kicker comp design help
  • 3
weedy
I have a 2001 Chevy Silverado, Ext. cab. I want to put all 4 under the back seat, face down. I have a 1000 watt ssl evolution monoblock amp to power it.
Questions:
Sealed or Ported?
would 4 be possible? if not two?
8 g.a or 4 g.a wire?
Let me know if anyone can help me sketch up a design for my truck. THANKS!!
In theory you can, but you will likely run into issues with attempting to get the settings right on the amplifier. The reason being that each set of subs will be reacting different do to the difference in enclosures.
However, if you match the volume in the console and down fire the console sub(s) the same distance from the floor as the under seat enclosure you might be able to make it work.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
612
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
weedy
weedy
Naples, FL
pro-rabbit
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
