4 18s in a wall, 94 astro
sub-FATHER
Resurecting this sport
1,620
denver, CO.
so i have a complete build log here for you to check out i hope i did it right.
94 astro
4 18's, konoki based motor with 12 spoke basket (STEVE made)
1 kenetics 2400 under the hood
5 135amphr powerware cells in the rear
1 200A external voltage adjustable regulator 8 to 20V
2 runs of 4/0 directly from the alt to the back cells. NO FUSES ANYWHERE.
kenwood excelon HU
1 maxxlink
1 10way optidrive electronic crossover
4 set 5.25 mb quartz mids and tweets for rear fill
7 sets of 6.5 mb quartz mids and tweets in front doors
1 set of 6.5 mb quartz mids and tweets in the dash
1 mb quartz dicuss dsc4125 to the 4 sets of 5.25.s and tweets
3 mb quartz dicuss dsc4125 to ther front 8 sets of 6.5s and tweets
1 hifonics goliath xx is in opperation right now, have bought 3 others and waiting for the repair shops to get em back.
so 4 xx goliaths, one to each sub
or
im selling em all and getting 2 sd12k
and 7 more batts this winter for a total of 12.
the box will be made outta 2 layers of 1 inch and in seperate boxes, making them more sturdy. 15 cubes each box with port, tuned to 27 hz
so i have a complete build log here for you to check out i hope i did it right.2 runs of 4/0 directly from the alt to the back cells. NO FUSES ANYWHERE.
i dont know about that logic...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
They also help prevent fires
when you got all your stuff hooked up right you dont experience that kinda problems.
lets take a good look at the logic here:
most big amps dont come with fuses right?
and your running 2 runs of 0 or 2/0 directly to your amps and your gonna conveniently take that girth down to a hair of soldier.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
check your decibles with and without the fuses. you will gain 2 db without em because your amp is getting the full juice it needs. but if you have doubts about your ability to wire than yah fuses are for you.
so far this van has done a 153.9 on one amp at .25 ohms
and done a 155.2 legal with 2 amps and the 2nd amp was smoking and at 25% power
and did a 156.3 outlaw and the 2nd amp popped.
43hz is the sweetspot so far. i cant wait to get one of my repaired goliaths back from ampjunkielikeme. then i will test and test and find out what the van can do.
Have you tested this before? I have my power fused and its only a short run in the trunk... Seems stupid having it fused now that I think about it.
Looks nice and thanks for small pics. Still using dial up here.
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
12
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
sub-FATHER
sub-FATHER
denver, CO.
sub-FATHER
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
