4-Ch. Selectable Amp, 2 speakers, and Bridged Sub. Wiring Question..
  • 2
xchobox
Hello, Kind of a noob to this wiring setup and I need up help with the proper configuration for wiring this set up...
This is what I'm trying to hook up:
Aftermarket stereo with 2 preamp outputs
A 4-channel amplifier with selectable 2-3-4 channel selection....... I am assuming it is 3 correct?
1 set of component speakers
1 subwoofer
I've got everything installed... I really just need help with the proper way to hook up my stereo to my amplifier.
1) On my amplifier it will be a 3-channel set-up correct? (1 set of speakers and a bridged sub)
2) With 2 preamp outputs on my stereo, will this be enough for the speakers and sub?
Hope this is isn't too vague lol
Basically what I am asking is....
I would need two preamp outputs correct?
So if I got an equalizer with two RCA outputs that would be sufficient?
Yes, you have it in 3 channel mode, you just need one set of RCA for the front components into the amp and one set for the back subwoofer
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
315
6
453
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
743
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
541
xchobox
xchobox
Nebraska
All_Logix
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
