4 channel running 4 6x9's and 2 super tweeters???
  • 4
Only The Best
texas
so i had a question.... if i got a 4 channel fosgate p400.1 (50rms@4ohmx4/100rms@2ohmx4/200rms bridged@4ohmstable).... i was wondering if i could wire my 4 6x9's (both 4ohm and 100rms)in parallel and bridge it and run my super tweeters off of the other channel....
you can run the 4 bynines off 2chs bridged, but wiring them in parallel will change xover point/slope. then run supertweeters off the other 2 chs.
My suggestion would be to get a cheapo 2ch for the supertweeters....
6
117
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
553
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
306
Only The Best
Only The Best
texas
mlstrass
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
