4 channel vs. 5 channel?
  • 2
Only The Best
texas
yeah i was just wondering becuase i wanted to know if running 6x9's at the lower frequencies and super tweeters at high frequencies would hurt the amp for the setup
---------- Post added at 01:26 PM ---------- Previous post was at 01:26 PM ----------
cuz i have a 5 channel fosgate prime and its just getting wayy to hot and distorting at high volumes where it shouldnt be distorting. wandering if its just not strong enough
Sounds like you may not have the xover points set right and your clipping...
what would you say the frequencies should be set at for the amp if my front stage is the 6x9's and the rear is the super tweeters... i have the 6x9's atm at 60 and the tweeters at 400
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
401
6
490
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
861
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
488
Only The Best
Only The Best
texas
Only The Best
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
