4 l7 10s vs 2 custom built 18's
  • 4
tuckintaco93
holt , fl
ok i have these 2 18's i had built a while back and put them in my f150 , long story short the truck will be siting for a while , Now i have this 09 hyundai accent that needs a system , was gonna wall it but like having a back seat so my question is with the 7-8 net cubes i can get behind the rear seat what would be a better option the 2 18's i have , or i also have 4 kicker l7 10's i could put in there
Also not really going for split for comps mainly a loud daily ,ground pounder , what about the 2 18's sealed ,might just end up running the single 18 but I think it may be to quite but also this car is so small
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
tuckintaco93
tuckintaco93
holt , fl
tuckintaco93
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
