(4) Powerbass 4XL-80-94 8" Mid Bass Drivers
  • 3
350zkid
1. Product:
2. Specs:
Features
Infinite Baffle Mid Bass Performance
Shallow Mounting Depth
Spun Aluminum Phase Plug
Treated Cloth Accordian Surround
KSV High Temperature 4-ohm Voice Coil
Chrome Push Terminals
Power Handling (RMS/Peak): 150 watts /300 watts
Nominal Impedance: 4-ohm
Voice Coil Size: 2 in KSV Voice Coil
Frequency Response: 90Hz - 10,000Hz
Sensitivity: 94 dB
Motor Structure: 35 oz.
Mounting Depth: 3.34 in
T/S Parameters
VC Impedance (ohms): 4 ohm
Test Impedance: 3.4 ohms
Fs: 35.46 Hz
SD: 226.98 sqCM
Vas: 16.6 Ltr
Cms: 227.08 µM/N
Mms: 15.8 g
BL™: 7.42
Qms: 2.953
Qes: 0.440
No: 1.833%
Spl: 94.6 dB
Xmax: 1.4 mm
3. Description/Condition:
Used, Works perfectly. Looks great BESIDES (1) Of The Woofers Has A Bend In The Mounting Ring. The Mounting Frame Is Weak IMO Bends Easily. Nothing That Affects Performance, If Mounted Up It'll Most Likely Flatten. 92) Have All Original Packaging, (2) Come In Non Original Packaging, Stuffed Up.
4. Price: :
I'd Like To See All 4 Go $120 SHIPPED
NO TRADES
iTrader via CACO = http://www.caraudioclassifieds.org/forum/members/350zkid/
5. Pictures:
350zkid
350zkid
St. Petersburg, FL
Blaza33
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
