4" coils, spiders, 12" cones
  • 4
beatnbronco
This is a list of a few parts I need to finish up some builds so if anyone can help me out with any of these parts i'd appreciate it. Trying to keep it low budget cuz the subs are for relatives and I'm not charging them but i'll do the best i can to pay what's needed. Thanks
1x coil to fit concept csp motor, gap measures: 3.83"ID/4.17"OD gap depth 4.18". Needs to have atleast 6" former
1x 3.96"IDx4.17"OD coil, 4" former, 2"ww
2x coils to fit 4" rockford power motor, coil measures 3.96"ID x 4.13"OD former is 2.5" and 1.50" winding width
2x 12"x4" cones, prefer power hx2 type cones, paper pulp w/fat butyl rubber surround
4x 8"x4" spiders
1x 8"x3" spider
4x 9.25" or bigger OD x4" ID spiders, if 3" ID i can cut it out for 4" coil
Hit up Springfield Speaker Repair. They were the last people to have new old stock Rockford softparts.
Good luck. This is why I stay away from 4" coils. Parts are not easy to come by.
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
994
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
beatnbronco
beatnbronco
Columbus, GA
joelnacy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
