40AH lifepo...Still Have Voltage Drop
illridge
CarAudio.com Recruit
29
usa
46258
I'm still dropping into the low 12's or lower with 40ah lifepo4 bank.
I'm trying to run ~2-3k rms.
Stock gm alt is 160amps.
Largest draw i've clamped on my jp23 is 120-140 amps on music.
I've clamped my alternator-- normally 40-50amps@ idle.
So where is my weak link?
40ah of lithium just not enough capacity or i got something else going on???
It'll probably drop in a few minutes.. depending on how hard I push.
Checked some measurements tonight....
JY40 will draw only ~50amps when you first start the car.
It will stay pretty consistent for a few minutes until the voltage climbs up to 14.0
The battery/ car sits at 13.2v with the key off. Agm up front hooked in parallel.
Sub sits at 1.4ohm nominal--- just checked that tonight too.
Amps never drew over 40amps tonight, so no voltage drop to test....
But i bet i'll start sagging with 100amps continous draw
46626
added a 32AH bank to my system......
Cot damn! Now we rockin.
Voltage staying above 13 wide open!!
Just thought I'd update.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
illridge
illridge
usa
illridge
    May 18, 2024
    May 18, 2024
