468lbs in the trunk upgraded rear suspension?
same boat with my explorer. closer to 600 pounds in the rear though. my shocks need replaced anyway... alot of people tell me go with air for the rear but i dont want to screw up the way it rides?
i have just shy of 800lbs.. its enough my 5.3 feels like a 4 banger civic.. dam near boggs down.. im going to have to get a chip if i put anything else back there
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
817
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
nate2587
nate2587
Lambertville, MI
wazzapkid91
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
