4th order band pss box help & commision
tlh21tlh21
Hello,
My name is Tyler. I'm building a car (2008 Mercury Grand Marquis). From what I have read you are the go to guy for information and help on this. I'm looking to build a 4th order bandpass box that vents into the cab. I would like to go with 1-4 8's (most likely 2) with the following brands:
Massive Audio SUMMO 84 Massive Audio SUMMO 84 8" Summo (Sumo) Series Car Subwoofer (first pick)
Massive Audio Hippo 84 Massive Audio Hippo-84 8" Hippo Series Car Subwoofer
or 2 12s
Massive Audio Hippo XL122 Massive Audio Hippo-122 12" Hippo Series Car Subwoofer (second pick)
Massive Audio SUMMO 124 Massive Audio SUMMO-124 12" Summo (Sumo) Series Subwoofer
If you have any questions I can be reached here, or via call or text 4076681798
if you do come up with a design I will pay you.
thank you in advance.
Ive got a similar car (2010 crown vic) and i was wondering how you plan to place the box. If your trunk is the same as mine, were you planning on place the box on top of the fuel tank directly below the rear deck? If so send me some pictures and some measurements and i will draw you up some plans. And what are type of bandpass were you looking for? Are you looking for full spl or are you looking for a good musical box that can get loud but will sound good overall?
I also have a 2004 and was looking at doing something exactly like this with 2 8" porting through the rear deck where the 8" factory subwoofer hole is via an 8" aeroport, any plans or ideas?
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
tlh21tlh21
tlh21tlh21
tampa, fl
BigMone0926
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
