4th order friendly 10" sub
Jroo
Looking to do a 4th order porting through the ski hole in my Volvo S80. Had good results back in the day with a similar set up using old round Kicker solobaric. Again, will certainly go the 4th order route with some of the port externally into the back seat/ski hole.
Need a single 10 inch that can present a 4 ohm mono load to amp (Older Rockford 800a2)
Works well in 4th order
Decent sound, not looking to be the loudest or meter or anything like that.
Can go to $300 but would like to stay around $250 if possible.
I have been told the DD 2500 series, but they are a bit more than I want to pay. Another person mentioned Sundown E series have been used 4th order. What sub would you recommend.
He seemed strongly against ported. Emphases sealed only a few times
It heavily favors the lows and has a faster roll off than other subs in the same enclosure but that's it. Tune it to below 30 and you have a monster.
As I look, what specs should I be looking at that indicate that it may work in 4th order. Ive heard a coupld of times, if the sub works sealed it works in 4th order? Another forum said low Fs and high QTs?
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
Jroo
Jroo
richmond virginia
Slobalt
Decebal
    Jun 10, 2024
