4th order or 6th order bp blowthrough design help
  • 5
I’ve actually done a 4th BP wall for 4 x-12’s. The one I did was like ~4.5-5 sealed and ~10 ported @ 44 hz. It was a lower playing musical 4th, not for SPL. Iirc port area for the ported section was around 16 in^2 per cube, so around 160 in^2 for 10 cubes.
You should easily hit a 150 with that equipment.
Thanks, I appreciate it
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
863
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
nightrunner268
CarAudio.com Newbie
nightrunner268
Hudson fl
nightrunner268
Latest topics
