SPLluminator 10+ year member
Hello all, I am currently building a box for a customer and I'm having second thoughts on my build design for the removable panel. Just curious if you all have pics of your removable panels so I could weigh my options. Here is the box (below) and the front will have 2, .5" acrylic panels so you can see the SA 8" V.2's inside. You can kind of see on the design but I was going to use 2 1/2" boards and laminate them after routing out a 3/4" lip on the top on so you can remove the acrylic. I am just curious if there are other/better options, Thanks!
I guess what I am really asking is if there is a way to bolt a board directly into the outside 3/4 in" board or will I have to have a lip to bolt to?
