4th Order
  • 1
Icecube91
Need some help. Thinking about doing a 4th order for 2 10" jl audio w6v3. Wanted to know how big the sealed and ported sections should be and what should the ported side be tuned to. Also want to know if a 1:1 or 2:1 ratio would work best? I have them in a ported box right now that's 2 cubes net volume and tuned to 30 Hertz. I mostly listen to rap music so I want to hot those nice lows. Amp will be a jl audio hd 1200/1.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
Icecube91
Icecube91
Vancouver, BC
Icecube91
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
