5 Channel to factory HU
Hi! I bought a 5 channel amp and I had a quick question regarding the installation of this amp to the factory radio of my 2010 ford f150 xlt with sync(with the basic sereo system).
I want to hook up 4 speakers plus 1 subwoofer. I know I have to convert the high level signal of the radio to low level and then the amp. I got myself two low level converters, one with 4 rca outs for the 4 speakers and one with 2 rca outs for the sub.
Now my question is this: Tell me if i'm wrong but I think I have to take the wires + and - from the LF speaker and feed the low level converter, this will be transformed to low level so I can feed my amp to the first channel with the rca's. Next I have to do the same for the RF, the RR and the LR speaker. But what do I do for the sub? Do I have to split the RR and LR speaker wires and then feed my second low level converter and then to my amp?
I hope the way I explain is good but if you have anything that needs to be explain better please let me know.
Thank you for the answer
ok, thanks e1 for your replies, but I don't want to have a processor or something like that because I already have my loc and I know I could install a new HU, but I want to keep my stock radio. Now the question was that I wanted to know if I was correct saying that: I have to take the wires + and - from the LF speaker and feed the*low level converter, this will be transformed to low level so I can feed my amp to the first channel with the rca's. Next I have to do the same for the RF, the RR and the LR speaker. But what do I do for the sub? Do I have to split the RR and LR*speaker*wires*and then feed my second*low level converter*and then to my amp?
Thanks again for your other replies.
What Loc do you have?
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
319
6
455
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
839
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
soundstream5ch
Qc, Canada
Chipmunk2k3
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
