6-Channel Clarion XC6610
  • 1
trumpet
Barry Schanz
Clarion XC6610
Used
Design derived from the works of the legendardy Robert Zeff. This is not a Zeff designed amplifier, but read this review and decide for yourself if this is a worthy amplifier:
Clarion XC6410 Amplifier Review
...In a word, the amplifier sounds excellent. I'm used to having to put up with a bit of telltale class D “hash” from a lot of full range class D amps, but the XC6410 has none of it. As in zero. Nor does it have any type of audible noise or hiss – even with the gains fairly high and my ears only a short distance from my tweeters. Clarion has come up with a really good sounding amplifier here and I'm having a great time testing its mettle with a variety of musical genres at both low and high volume levels.
6/5/4/3 CHANNEL CLASS D AMPLIFIER MSRP : $649.99
・ 1,000 Watts of Maximum Power Output
・ 250 Watts x 3 Channel @ 4-Ohms Bridged
・ 125 Watts x 6 Channel @ 2-Ohms
・ 85 Watts x 6 Channel @ 4-Ohms
・ Conformally Coated PC Board
・ Stainless Hardware
・ MOS-FET Power Supply
・ High/Low Pass Electronic Crossover, 50Hz-500Hz
・ Variable 12dB/Oct. Bass Boost for CH5/CH6
・ Variable Gain Control
・ 2 × 40 Amp ATC Fuses
・ Switchable High Level Auto Sense
・ Soft Turn-On and Turn-Off Circuitry
・ Ground Loop Isolation Circuit
・ Corrosion Resistant RCA, Power, and Speaker Connections
Class D Amplifier Design
Using MOS-FET power devices, the Class D amplifier circuitry is able to deliver incredible performance in compact dimensions. In a digital amplifier a Pulse-Width Modulator (PWM) expresses a low-frequency audio signal as a wide pulse, and a high-frequency audio signal as a narrow pulse. This then undergoes digital-to-analogue conversion for output, which is the basis of any digitally recorded media hence excellent affinity to digital sources. High power conversion efficiency means less power wasted and less heat generated, therefore an absence of bulky heat sinks.
Circuit Design Achieves High Quality Sound
Clarion amplifiers feature uncompromising resistance to magnetic noise, thereby minimizing distortion, as well as high quality block terminals to offer low electrical and contact resistance. Easy subwoofer system configuration is possible with the embedded high pass and low pass filters. The result is high quality sound you can enjoy in a variety of systems.
Corrosion Resistant RCA and Block Terminals on all XC series* Amplifiers
By utilizing corrosion resistant RCA and block terminals, XC series amplifiers offer improved durability and reliability in harsh environments. The XC series* amplifiers are true marine amplifiers with oversized aluminum heatsinks and locking power terminals for the harsh marine conditions.
* except XC1410
MOS-FET Power Amp
There' s only one way for Clarion' s main units to deliver unyielding power output and linearity: MOS-FET amplification, or Metal Oxide Semiconductor Field Effect Transistor amplification. Smaller and more efficient than conventional power supplies, a MOS-FET amplification circuit delivers power with less distortion and zero On/Off switching noise. This means you can crank up the volume or set it to easy listening. Either way, your sound will be crystal clear.
2-Ohm Stability
Utilizing this design for peak performance and unwavering reliability, Clarion's amplifiers can drive lower impedance loads for increased power.
CEA Power Output:
 125W × 6 RMS (2Ω@14.4V≤1% THD+N)
 85W × 6 RMS (4Ω@14.4V≤1% THD+N)
Signal to Noise Ratio:
 80dB (Ref; 1W into 4Ω)
$350 shipped OBO
Free ground shipping to the Continental US.
All other locations require a QUOTE.
The pictures show the amplifier fresh out of the box. Aside from some trunk dust it looks the same today.
I have 2 of these for sale. The second amp is a little more scratched but still at 100% operation. These are fantastic sounding amplifiers.
174
399
10
793
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
452
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
