6' Ports?
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif 6' ports
jk partsexpress has them http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-354
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
12
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
autosportsunltd
autosportsunltd
Clarksburg WV
kush-divinity
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
