$7000+, but.........
Rich B
GENESIS p-15
¢£¥ì¥¢¥¢¥ó¥×¡ª GENESIS p-15 Á´À¤³¦100Âæ¸ÂÄê¡¡ºß¸Ë1Â梣 - Yahoo!¥ª¡¼¥¯¥·¥ç¥ó
Anyone want to buy a kidney?
■ ■ Specifications
Hybrid-Amplifier Limited Edition
Rated power 4 ohm: 2 × 30 W rms
Class A mode 2 ohm: 2 × 15 W rms
Typical power 4 ohm: 2 × 34 W rms
Class A mode 2 ohm: 2 × 18 W rms
Rated power 4 ohm: 2 × 200 W rms
Class G mode 2 ohm: 2 × 300 W rms
Typical power 4 ohm: 2 × 290 W rms
Class G mode 2 ohm: 2 × 430 W rms
1 × 800 W rms @ 4 ohm bridge
Tube Pre-amp (Russian 6H30Pi)
S / N ratio:> 100dB A weighted
Channel separation:> 100dB @ 20 Khz
CMRR (Balanced Input):> 60dB, typically> 75dB (20Hz - 20 KHz)
Input Sensivity: 0.5 - 5.0 Volts 8.5 Volts Pre-Out compatible
Idle current: 8 +8 A
Max current: 53 +53 A
Weight: 17 Kg
Rich B
Rich B
*under the rainbow*
chillin
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
