8" sub recommendations
tooshort_128
I'm planning to install a budget system in my 2017 F-150 and finally want to try 4 8's. The box will be sealed and will have about .4 cubes per sub. My budget is at $200 so I was looking at some Skar IX-8s (cheapest option) and NVX VSW8s. Are there any other budget friendly 8's out there that will sound decent? I'm not concerned with spl but the lower they hit, the better.
if youre looking at 1.2 cu/ft sealed, why go with 8"s? you could get a very good 12 for around 200 and blow the 8s out of the water
I’ll have 1.6 cubes for all 4. Why not skar? Are they that bad? I’d be interested in the MB’s if they weren’t shallow. The subs will be under the seat down firing but don’t need to be shallow. Ive got over 5” of mounting depth to work with so full size subs will work. I feel like the shallows won’t have the excursion to hit the lows.
203
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
542
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
572
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
669
tooshort_128
tooshort_128
Sterling, VA
shredder2
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
