A couple power related questions.
  • 1
4BangerStanger
CarAudio.com Regular
117
5
DFW
I am about to order the all the wires etc for the new system I'll be putting in my 2019 F150 super crew. The amps will be a SoundQubed S1-1250 (for 3 8" NVX subs) and a S4-100 (will run a set of 6.5" mids and a pair of 1" tweets - have not been selected as of yet). The source will be the factory head unit running through a Dayton DSP-408. I'll be running 1/0 cable from the battery to the distribution block near where the amps will be. I definitely plan to continue the 1/0 to the 1250, with a reducer. But, should I run it to the 400 also? Or would 4 guage be enough for that one? Also, the power wire for the DSP are part of the wire harness. Should I run the power and ground along with the speaker wires etc to the head unit? Or should I split those off and run those to the distribution blocks with the amps?
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
7
919
4BangerStanger
4BangerStanger
DFW
4BangerStanger
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
