A couple wiring questions?
  • 1
Hippyplz
I'm installing a sundown saz 1500 and a sax 150.2 in a 94 ranger. The plan is to run 1/0 ofc from the front battery to a 2nd in the bed with a fuse at both ends. From there a run of 1/0 to the the 1500 and 4ga to the 150. I'm not sure what I'm going to do for batteries or alt yet, but does this sound ok for the wiring?
Sent from my SM-G935V using Tapatalk
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
262
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
658
Hippyplz
Hippyplz
Pekin, IL
Hippyplz
