a little help
  • 1
chris765
ohio
i am going to purchase an Alpine SWR-T12 and it will be the only subwoofer i am limited on my enclosure since it is under my seat of a 2001 ford f150 Ford F-150 Supercrew Cab 01-03 Dual Subwoofer Box is the box but end of day i have had alpine type r's and have heard the shallow mount subs in ported and would prefer ported i realize this is more or less a prefab box but i would like to put a tube port in and i am confused on how to calculate the legnth and diameter if anyone could give me some advise i would apreciate it
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
432
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
523
chris765
chris765
ohio
chris765
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
