a lot of b/n woofers for sale, mostly old school
  • 6
nudels
KNOCK-KNOCK!, MOFAKOO!
1. (3) bnib aura 12000 rpm's (12")
2. (3) bnib hollywood soundlabs hsl 125d's (12")
3. bnib rainbow hammer (12")
4. bnib arc audio 8d4 (8")
5. bnib volcano xk2 cannibal 12c (12")
6. (2) universal electronics 'black max' ues-804, (8") one sagging from being inverted for 10 years
7. (4) bnib pinnacle 8" poly woofers
8. b/n clif designs 12"
9. b/n clif designs poly 10"
10. b/n sunrise speakers 12"
11. b/n m&m godfather 10-4 (10")
(lots more to add, still)
all b/n, tested for proper sound/operation is the furthest these have been powered
1. (each) 2" single 4ohm, 250w rms, semi-transparent poly cone, santoprene surround, bbp (bumped back plate) fs-24hz, qts-0.53, vas-6.0cuft, mounting depth-5.125", cutout dia.-11", driver displacement-0.06cuft
2. (each) 2" dual 6ohm, 200w rms, poly cone/dustcap, foam surround, 'mag. flux optimizing structure ('mafos') design, bbp, fs-26.7hz, qts-0.64, vas-6.3cuft, 88.6db @1w/1m
3. 2.5" dual 2ohm, 400w rms, poly cone/dustcap, santoprene surround, cast basket, bbp, fs-28hz, qes-0.34, qts-0.32, Le-3.21mH, vas-60L, Sd-510sqcm, Xmax-23mm, driver displacement-4.3L
4. dual 4 ohm, 150w rms, poly cone/dustcap, santoprene surround, fs-24.7hz, qes-.367, qms-3.572, qts-.332, vas-1.55cuft, Xmax-15mm one way linear, Sd-231sqcm, 85.6dB@1w/1m
5. 2.5" single 4ohm, 3-400w rms, high density paper cone, poly foam surround, 8 spoke cast basket, bbp, fs-34.7hz, qts-0.54, vas-2.7cuft, 94dB@1w/1m, oem'd by stanford acoustics
6. (each) 2.0" vented single 4 ohm, bbp, 125w rms, fs-37hz, freq range-30hz to 3.5khz, qes-0.45, qms-3.84, qts-0.40, Re-3.4ohm, vas-39.39L, 92dB@1w/1m
7. (each) 2.0" single 8ohm, poly dustcap/cone, butyl surround, bbp, 30oz mags,
Re-6.0264 ohm, Fs-29.0347 Hz, Zmax-57.2313 ohms, Qes-0.2905, Qms-2.4681, Qts-0.2599, Le-3.0598 mH (at 1 kHz), Diam-168.2750 mm (6.6250 in), Sd-22239.7074 mm^2( 34.4716 in^2), Vas-42.5656 L (1.5032 ft^3), BL-13.7012 N/A, Mms-49.5988 g, Cms-605.8093 uM/N, Kms-1650.6844 N/M, Rms-3.6661 R mechanical, Efficiency-0.3370 %, 87.2945 dB @1W/1m
8. 2" single 4ohm, graphite injected reinforced pulp cone, poly dustcap, butyl surround, bbp,.. not much info on this, can pull t/s parameters upon request
9. 2" single 4 ohm, poly cone/dustcap, foam surround, bbp,.. same as the 12", can pull tsp's upon request
10. 2" single 4 ohm, rigid 7 rib paper surround, poly dustcap, santoprene surround, 4spoke cast basket, dual slug motor structure,.. again, not much known about this driver other than it seems to be built quite well for a sq application
11. THE very last m&m godfather 10" to leave gefco speaker manufacturing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif, 1.5" single 4 ohm, foam surround, reinforced paper cone, bbp,..
Re = 3.6979 ohms
Fs = 28.2472 Hz
Zmax = 26.5664 ohms
Qes = 0.5084
Qms = 3.1442
Qts = 0.4377
Le = 0.8358 mH (at 1 kHz)
Diam = 206.3750 mm ( 8.1250 in )
Sd =33450.6109 mm^2( 51.8486 in^2)
Vas = 106.1968 L ( 3.7503 ft^3)
BL = 7.8319 N/A
Mms = 47.5173 g
Cms = 668.0958 uM/N
Kms = 1496.7913 N/M
Rms = 2.6822 R mechanical
Efficiency = 0.4423 %
Sensitivity= 88.4755 dB @1W/1m
Sensitivity= 91.8269 dB @2.83Vrms/1m
all prices are without shipping
1. $40 each, $100/3
2. $40 each, $100/3
3. $150
4. $70
5. $130
6. $40/pr
7. $30 each, 100/all 4
8. $45
9. $35
10. $75
11. $150 firm
everything gets insured and diligently packed
View attachment 26537507View attachment 26537508View attachment 26537509View attachment 26537510View attachment 26537511View attachment 26537512View attachment 26537513
bump for you ugly *******,..
offers will be entertained, trade or w/e,.. need to get some of this Sheisse moved
Where are u located man? Just wondering how bad shipping is gonna be if I go with three of those 12's.
zip code 60002
shipping for three 12's, either auras or hollywoods, will prob run around 40-50 bucks incl. insurance (typical, as ive sold and shipped over twenty 3-packs of 12" since march)
i can get an exact figure if you need, woofers are around 10 pounds each
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
I can hold a conversation with you and never hear a damn thing you say.
5
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
nudels
nudels
right here
nudels
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
