A pros help needed
  • 2
Well im going to change my current set up , 2 15 RE audio *** powered by a brz1200 in a 2000 audi a8 6cube box tuned to 38hz , port and subs up port aimed at cut out in rear deck. Sounds good but i think it should be louder and lower (cant do subs back, trunks not tall enough) i want to cut out the rear deck more and build the box in the trunk 8cube with subs and ports in rear deck sealed off from the trunk but im wondering what would be better. 3 6in pvc ports 85 sq inches of area tuned to 30hz or 2 8in pvc ports giving me 100sq in tuned to 30hz?
I agree with the brightness thing. I have mine set to black out in 5 seconds, lol. Never noticed the crossover issue since my dsp handles...
4
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
379
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
515
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
523
ringspun09
ringspun09
Blaine Minnesota
ringspun09
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
