AA 125.4 - FS/FT+Cash
  • 1
jasonbillnelson
LEAD, FOLLOW, OR GTFO!!!
1,291
La Plata, MD
Ampere Audio 125.4.
Brand New, never seen power, only taken out of the box to test fit. It was too big for where I wanted it to go.
$350 Shipped/insured via FedEx to CONUS (If you live out of CONUS, I will consider shipping to you but I will not pay any customs fees, and shipping will be on your dime.)
Shipping and PP Fees on me.
If you want to trade something, it needs to come with cash. I'm looking for at least $250 in cash plus your trade so keep that in mind with what you're offering.
The AA-125.4 has a flexible crossover that allows the user to run a 2-way active speaker setup with no external processing.
Rated power output
RMS power, 4 ohms stereo--------> 125W x 4CH
RMS power, 2 ohms stereo --------> 200W x 4CH
RMS power, 4 ohms bridged--------> 400W x 2CH
Signal to Noise Ratio--------> >90Db
Low Pass Crossover --------> 50Hz ~ 5KHz
High Pass Crossover--------> 50Hz ~ 5KHz
Frequency Response--------> 10Hz to 500Hz
THD@RMS Watts -------->
Variable Subsonic Filter--------> 10Hz ~ 40KHz (+/-1dB)
Variable Subsonic Filter --------> 10Hz ~ 40KHz (+/-1dB)
Channel Separation--------> 75dB
Fuse Rating --------> 30A x 3
Input Sensitivity --------> Variable 200mV~6V (+/- 5%)
Dimensions(mm) --------> 256(W) x 55(H) x 480(L)
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
12dB Octave Variable Subsonic Crossover Slope
Independent 1/2 and 3/4 Channel High Pass
Filter Variable with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass
HPF/FULL/LPF Selectable Switch
Electronic Crossover Slope Selectable Switch
with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry
(Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD:
14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
4
jasonbillnelson
jasonbillnelson
La Plata, MD
jasonbillnelson
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
