ACC touched R/R + Need help!! :-(
adamwilson301
While trying to get my power antenna and 12" woofers to work at the same time (they are now) I accidentally touched the Violet (Rear right Speaker +) to the Red (+ 12V ignition Wire) and now none of my 12 speakers are getting sound to them. But my 2 subwoofers are. I checked every fuse 3 times none are blown. I know I should of taken the radio fuse out I just got cocky and did it thinking meh its only 4 wires im redoing nothing will happen... Well now my antenna works great but what good does it do me if I cant listen to what it receives lol.
I also checked the fuse on the back of the Panasonic Head unit too it is good.
Anyone know where something went wrong? I need help bad lol no radio is torture.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Thanks, Brian.
:-( I am a teen I was eager to get it working been at it for days n hours just got to impatient to keep doing that I took the fuse out taht gave it power every time sept that one though :-(
Okay now we are getting somewhere. I just uncrimped them by mistake so I could crimp the antenna wire and the sub wire. I didnt realize I uncrimped the Violet one it looked pink and the Schematic I saw said pink was the GM stock antenna wire color stupid auto pilot brain of mine.
So here is where you see just how illiterate I am with electronics.
What is a where is the outputs and what is an HU.
And can I fix this myself? WHat will I need to buy and about how much would it cost?
HU = Head Unit = Radio (ur panasonic)
9 times outta 10, your speaker outputs (speaker wires coming out of HU) are shot. Just run a 4 channel amp for front and rear speakers, and you'll have a dead head (no speaker output, just RCA)
Thanks. and thank you all for your help! I really appreciate it!
Okay got the HU out there is not a way to tell by looking at the outside if the outputs on the HU are shot?
incase these would somehow help lol
can't look on the outside. you got a dmm? if so, hook it up where it should be playing and test the speaker outs to see if they are working
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
888
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low...
Hey guys hoping some one can point me the right direction. I have a full hertz Car Audio set up and, I’m having trouble with the hertz H8 DSP I...
adamwilson301
adamwilson301
Waynesville MO
jco1385
