ACC touched R/R + Need help!! :-(
Are those wirenuts or some weird form of butt connectors? If they're wirenuts...take them off and do it properly because in time those WILL shake loose and you'll have even bigger problems on your hands.
they're crimp splicers
Are you really running 12 speakers off the head unit? Good way to keep blowing them up.
Well they are the 12 stock speakers + the 2 woofers. When you have a quality sound system most mistake for Bose I dont know where I am going with this but yeah people think its Bose all the time.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The Panasonic did just fine till i touched teh Rear speaker Posotive with to the ACC ignition wire. Unless I turned it past 24 then it would stop sending power to the speakers for a short time some sort of saftey feature to stop from overheating and destroying something.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I am sorry the decked out Trans- Am is to good for a regular HU //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
this is what was in it b4 but cant hook Subwoofers up to it :-/ It is a beastly Head Unit
I like it better then my new one lol
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
886
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low...
Hey guys hoping some one can point me the right direction. I have a full hertz Car Audio set up and, I’m having trouble with the hertz H8 DSP I...
adamwilson301
adamwilson301
Waynesville MO
jco1385
