ACCUVOLT Installation HELP!
  • 1
hometech99
9
SC
sure- Jacobs tech is closed till 1/5, and i need to get my install done this
week while im off ( i dont begrudge them being off also, but the company I
work for is still open at least).
i need to ask some questions because i hooked up my FR750W, and am getting
no voltage passthrough at the output terminals when off, and the green LED
flashed (with still no voltage at the output terminals) when 12v supplied to
the ON screw.
I have about 5 feet of 4G wire twisted pos/neg going to the input from the
battery.. i am powering a mac 420 (50*4), and one 200w sub amp for now.
also, to the left on the labelled input screws- there are a second set of
screws that the instructions dont show. i found out that these are POWERED.
also, the instruction show the word FUSE beside each input screw- there are
no fuses there.
i do not have the remote sense hookup in use- but- do you just leave those 2
screws unconnected to anything? each other? or, is it NOT optional, and they
have to be hooked to the output voltage?
help! this is the last step before sliding the headunit in and powering up
the system!
thanks
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
hometech99
hometech99
SC
hometech99
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
