Acura Integra - Install Tweeters in Factory Location
  • 1
JJ30
Do you own an Integra that didn't come with stock tweeters? That's okay! The only thing Acura didn't do was cut a small hole in the door. That is all. There are wires in the door for a tweeter, as well as a cutout where the tweeter would've gone.
Step 1: Tools
All I used was a sharpie and my WEN rotary tool (very inexpensive on Amazon) with a drill bit and then switched to a grinding stone bit.
Step 2: Adios!
Say goodbye to your old tweeterless door panel
Step 3: Measure Tweeter
If your tweeters didn't come with a template, measure them.
Step 4: Drawing lines
There's a small hole directly in the center of the cutout, this is where I centered the lines.
TIP: Draw a circle around the lines! I didn't think of it at the time but it would've helped a lot.
Step 5: Committed to the hole
Using the drill bit, drill a hole through the panel and create a big enough hole to be able to use the stone bit. Go to town with the stone bit, carving away ONLY the plastic (Not the fabric), checking to see if the tweeter will fit every 30 seconds or so, don't stay in one place too long or your circle will quickly become oddly shaped. I didn't carve away the fabric in order to fold it back, giving the tweeter a tight fit.
Step 6: Poke it in
After a few minutes perfecting your circle, it should finally be just the right size to accommodate your tweeter. (Repeat steps 1 through 6 for other door //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif )
Mission Success!
In less than 30 minutes you can turn your lame-o non-tweeter door panel into a less-lame door panel, woot!
For my build, I did not use the factory tweeter wires. I have speaker wire routed through the door grommets (NOT FUN) and into crossovers epoxied on the back of the door panel. Running off an NVX mvp4.
-JJ30
Are you planning on upgrading the alternator and add extra batteries?
767
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
😩 😩 😩 😩 😩 That deff sounds like azz man. Id run another ground wire from the HU to a good solid ground location cleaned off and bolted down.Id use...
JJ30
JJ30
Hillsboro, OR
JJ30
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
