Acura radio into older Accord - no sound
  • 2
jimbiker
CarAudio.com Newbie
I have a 1998 Accord in which the CD part of the radio doesn't work. I found a 2003 Acura radio/CD/Tape at the junk yard with the same 2 din size and same attachment and same 20 pin connector in the back and it had a known security code. Trouble is I don't get any sound out of it; it switches between modes, displays frequencies, but no sound. I researched the pin meanings of the 20 pin connector and pin 14 is navigation (mute) for the acura and security out for the accord. I figured pin 14 was muting the radio so I cut that wire. Then the acura radio displayed frequencies but still no sound and then the display went blank after 15 seconds and then the dome light in the car started to dim ... I was discharging the battery rapidly. I turned off the ignition and disconnected the radio and the car was so discharged it wouldn't start. I charged the battery remotely and the car still runs ... I was worried I'd fried the computer.
Anybody know what happened and if the acura radio is still viable how I can get sound? I am going to reconnect pin 14.
Since the last report, I reconnected pin 14 wire and the Acura radio operates like it did in the past ... displays but no sound. I think my problem is that there is an equalizer with this radio and I don't have it ... so another trip to the junk yard to get it.
Are you planning on upgrading the alternator and add extra batteries?
850
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
😩 😩 😩 😩 😩 That deff sounds like azz man. Id run another ground wire from the HU to a good solid ground location cleaned off and bolted down.Id use...
jimbiker
CarAudio.com Newbie
jimbiker
upstate New York
MattinMO
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
