Advice on an amp for ID CXS64v2
  • 2
I've already posted about this in the past, but i would really appreciate it if someone would educate me on this as last time i only really got one amp suggested to me.
MRX-F30 - Alpine 4 Channel 50W RMS Amplifier
D300.4 - Diamond Audio 300W RMS 4-Channel Class AB Amplifier
MRV-F300 - Alpine 4-Channel 300W RMS Amplifier
MIKRO IV - ZED Audio 4-Channel 440W RMS Advanced Class D Design Amplifier
SAE-50.4 - Sundown Audio Monoblock 300W RMS Class AB Full Range Amplifier
Could anyone please tell me of any of these would be a good pairing? Should i be looking into 2 channel amps instead of bridging 4 channel amps like these?I'm also curious to hear why one is better than another out of this group if you could be kind enough to educate me. Really want to get this last piece of my system decided on and ordered!
Thanks again
All of those amps would work fine in either bridge mode or 4 channel mode. I seriously doubt you will ever hear any difference at all between any of then. The zed has more flexible crossovers I believe. Only important if you want to go active. Timhof13 has a polk d4000/4 for sale in the classifieds I would probally choose before any of these. Its in the same price range also.
sorry for the late reply, but can i ask why that polk amp would be better?
It also lowers the amps efficiency and raises the current draw.
5
474
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
blackpanda1992
salisbury MD
joom
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
