Advise on mid sub
  • 4
To clear this up, the ES-6MO and HD-6MO mids are midranges that both are sold with standard size 1" tweeters in their respective 2-way component sets. If you want loud bass from a 6.5" subwoofer you should be looking at the CDT HD-M6 or ES-06+. They make a smaller, cheaper 6.5" subwoofer called HD-6MDVC, but the power handling is not ideal for SQL. They're great for my listening tastes, but I usually think my single 12" sub in a sealed enclosure is enough bass.
0.6 cubes sealed is larger than the recommendation I have for the ES-06+ subs I have in stock. This is better than too small as you can always fill the enclosure with something like duct seal to experiment with a different volume.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
414
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
8
785
gain set well below "Normal" and base boost is off completely
15
shadow
shadow
Dallas,Texas
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
