aero port question
  • 6
DMV1919
I'm gonna be building a ported box 1.75-2 (haven't decided yet) cu ft @ 30 hz for a Skar VVX12 given 800 watts @ 2 ohms by a Directed 1500d
The box will be going in the back of a camaro and according to this the best sub/port placement would be upfiring into the glass
I can fire the port towards the glass with a 3" diameter port with no problems, but if I use a 4" port, the port length is too long and i would have to have the port going to a side
Will a 3" port have enough port area or would i be better off with a 4" to the side?
Too small of a port creates port noise (chuffing). Too large of a port makes the box more peaky and performace below port tuning will fall drastically. (someone correct me if I'm wrong here, pretty sure I got it right though)
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
729
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
904
DMV1919
DMV1919
South Carolina
THATpurpleKUSH
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
