aftermarket dvd unit in GMC Acadia
  • 2
67 Fastback
I want to put a flipdown unit in my wife's Acadia using the dome light that has buttons for on/off. There are three wires one constant, ground, and a door ajar trip. I know I can tap into the constant for power but have read people having trouble with this killing the battery. I really want to be lazy and not rip apart her vehicle to accomplish this. Can I hook it up to this constant and put a snazzy toggle switch on the dvd unit (something that blends) to turn power to the dvd unit off when not in use to bypass this battery issue????
Bill
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
711
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
893
67 Fastback
67 Fastback
Southeast, KY
67 Fastback
