Aftermarket exhaust tips....
  • 4
exaust tips dont make youre car perform any better just make it sound more agressive to make it sound good and perform better you would have to upgrade the hole exaust system
Exhaust tips will only make your vehicle sound different if they have a resonator or some other kind of baffle or flo system in it. Just adding a chrome tip to your pipe won't do anything except add a flash to it.
Peace...(yeah,right!)
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
653
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
750
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
dkim1385
dkim1385
Midland, MI
Hellrazor
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
