Aftermarket Stereo Turns on my Car!
kcoll98
I have 2004 Ford Mustang. I'm replacing my factory stereo with an Innovatek in-877gps. My friend and I have it all hooked up with all the wires matched up together (or at least we are pretty sure).
The thing that happens is when we hit the power button to turn it on and test it, it turns my car on if the key is in the ignition and turned only to run the battery! It turns on, and keeps trying to turn the engine even though its on. If the car is turned on fully, and we hit the power button, it attempts to keep turning the engine.
We tried switching the constant and switched(ignition) wires thinking maybe the wires were switched on the new stereo, but it still did the same thing.
Any ideas or suggestions? Let me know if you need more info about anything. I'm not really a car guy, haha.
if you arnt 100% sure on wiring, don't do it. ask som1 who knoes befor your car burns itself to the ground
Never ignore this warning, if you do, expect smoke and then fire. With electrical fires there is no way you can put it out unless you disconnect a glowing red hot battery cable from the battery or till the battery dies from poor maintenance.
Ill bet your remote is connected wrong. I had a mustang that wanted to this. The remote wire was connected wrong. Something about a radio fuse. This is the fuse that starts the car
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
710
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
kcoll98
kcoll98
Orlando, Fl
jteske88
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
