Ahhhh!!! Help
danparkinson
Okay well first off i just bought a new head unit, its a jvc kd r600. I had replaced the jvc with a new jcv which is the kd r600 bc i thought that was the problem. I had got an amp from my buddy its a 580 dual amp 2 channel, I already had the sub. Its a sony xplod 800 watt 4 ohm, well after going to get all the wires and everything i then installed everything and after it pounded for a 10. When i first installed it my old jvc head unit was still in the car. It worked fine for about a month i would say, then i disconnected the amp and the sub because i had to put a lot of stuff in my trunk. After that day its never been right and for the last month i have been trying everything i know to get it back to working but nothings changed. When i hooked everything back up it worked but didn't hit hard at all, so i thought i maybe hooked a wire up wrong, but nothing was wrong ground was fine, rcas were fine, power was getting 12 v constant and remote was hooked up fine on head unit and amp. After looking at everything and not finding anything i said whatever. Well i let it go for about a week then i looked at everything again and i couldn't find anything!! it only got worse from there it went from not hitting hard to cutting in and out, to it cutting out my speakers. SO after everything i said fu** it and went and bought a brand new 115$ jvc head unit. After installing everything i hooked the remote up etc. The **** thing is still doing it!! I have tried 2 other amps and 2 other subs and its doing the same thing. Im ready to just sell them but i don't want to. I am completely out of ideas... Please HELP
i said "ahhhh real monsters!!!!".
Didn't see that one coming. Seriously funny. Lmao.
As far as the problems go, and take this with a grain of salt as I'm still new to this game, it almost sounds like a dirty connection or something faulty within the amplifier. I would disconnect, clean, check and recheck all of the connections and see if that helps at all. It can be a tedious task, but it never hurts.
I would take that amplifier to my local car audio shop, and get it tested,Some charge very little,and some do for free..Be a good start
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
496
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
540
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
571
danparkinson
danparkinson
Pittsburgh, PA
>>SQL<<
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
