Alpine 30wx2 amp pushing two eclispe 12
  • 4
danielwhitlock3
ok so I put a new audio system in my 2010 nissan versa and I had an old alpine 30wx2 amp lying around so that is what I connected to my subs this seems weird cause its so small but it actually works my subs shake everything in my car the mirrors even vibrate so hard you can't see anything in them I have a factory radio cf17y so I put a generic line output converter in it as well can someone explain to me why this amp is pushing two subs that should eat its breakfast without any help I never would ha e thought it ahould push them this hard
You said old Alpine amp. If its from the 90s, I would believe it. I had an Audison from the 90s 2 x 45 w that ran 2 subs and front end with punch. Big amps little numbers in those days especially when u loaded them up. They got hot but kept pumping out the watts. Then there was the Orion 1 watt concept. The reason for this was the sound off rules. They were categorized by wattage so manufacturers were producing under rated amps before going the other way for a while. It would be interesting to see which model it is if you can provide us with the details?
I, too, have an old school Alpine 30w X 2 amp (3547). It's good to run component speakers/tweeters. As for pushing subs shaking the car, I highly doubt it.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
204
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
477
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
danielwhitlock3
danielwhitlock3
Arkansas
nvturbo
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
