COMPLETED Alpine 3656 Active Dividing Network
  • 2
Stilldouble
CarAudio.com Newbie
9
Sweden
Price
$400
Condition (1 worst - 10 best)
7
Fully configurable, 6-way signal division:
6 outputs: 2 Rear (Mid and High), 3 Front (Low, Mid and High) and 1 Subwoofer.
Separate Front and Rear inputs.
Capable of running a full system with front and rear channel fader.
Independent circuitry and outputs for Front, Rear and Subwoofer.
Continuously adjustable crossover frequencies.
Selectable Non-fading (constant), Front-fading, or Rear-fading Subwoofer output.
Independent crossover frequency adjustments for Subwoofer, Front Mid and Rear Low outputs: allow for staggering or overlapping the outputs to emphasize certain frequencies or eliminate resonances.
Phase switches for the Subwoofer, Front Mid and Rear Mid outputs: can be used to eliminate standing waves and system imaging problems.
Stereo/Mono switch for the Subwoofer output: allows the use of mono or single-speaker subwoofer systems.
Continuously variable output level controls for all outputs: allow compensation for different speaker efficiencies, amplifier sensitivity and/or system frequency response shaping.
24K Gold-plated RCA Input/output Connectors: for most accurate signal transmission, lowest loss possible, and immunity to signal deterioration that can be caused by corrosion in the connectors over time.
24K Gold-plated, screw-type power connectors: for optimum voltage, current transfer and excellent oxidization resistance.
High performance, low noise, audiophile quality active and passive components.
Trunk-mount, hide-away unit adjusted at the time of installation (no user-adjustable controls).
Remote-on indicator LED: confirms operation of the unit.
SPECIFICATIONS
Number of Outputs: 6 (fully configurable)
Possible System Configurations.
  • FRONT: 1, 2 or 3 way
  • REAR: 1 or 2 way
  • SUBWOOFER: on or off
Output Level Control Range: SUBWOOFER OUTPUT: 0 to +12 dB. ALL OTHERS: 6 to +6 dB
Overall Frequency Response: 10 Hz to 50 kHz (+0,-1 dB)
Signal-to-Noise Ratio: 100 dBA
Input Sensitivity (for 500mV output): 500mV
Input Impedance: 10kΩ ΜΙΝ
Output Impedance: 1kΩ ΜΑΧ.
Filter Type: Second-order Butterworth
Was Photo Included
  1. Yes
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
317
Lower price Subs: $275 shipped Only selling one set of 6.5, keeping the other $100 shipped
7
842
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
651
Stilldouble
CarAudio.com Newbie
Stilldouble
Sweden
Stilldouble
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
