Alpine BBX-F1200 4 Channel Car Audio Amplifier (BBXF1200) with Amp Kit (BUNDL...
  • 4
audiojamonline
CarAudio.com Newbie
ALPINE BBX-F1200 4 CHANNEL CAR AUDIO AMPLIFIER (BBXF1200) WITH AMP KIT (BUNDLE PACKAGE)
R2AK4 4 GAUGE AMP KIT WITH PURCHASE
Get a Raptor R2AK4 4 Gauge 4 AWG Complete Amplifier Kit with your purchase.
17ft CCA power wire
3ft CCA ground wire
17ft RCA
ANL fuse holder with 100 amp fuse
Hardware included
For up to 1100W Systems
CCA (Copper Clad Aluminum)
Retail Cost: $49.99
GENERAL
  • Amplifier Type: Class-A/B
  • Channel Design: 4/3/2 Channel
  • Thermal Control: Thermal Management Control
  • Power Supply: DC-DC PWM Power Supply
  • Power Supply Design: MOSFET Power
  • Current Protection: Over-Current, Over-Voltage and Thermal Protection
  • Crossover: Variable Low-Pass / High-Pass
  • Green/red status LED
  • 2 pair RCA pre-inputs
  • Power Requirements: 14.4 V DC (11 V to 16 V)
  • Input Sensitivity: 0.2 - 8.0 V
  • Frequency Response: 5 Hz - 50 kHz (+ 0,-3 dB)
  • Speaker Impedance: 4 or 2 Ω
  • Signal to Noise: S/N Ratio (IHF A Weighted, Reference: rated power into 4ohms) 95 dB
  • Weight: 2.7 Kg
INSTALL
  • Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals
  • Terminal Layout: Two-Sided
MAX POWER OUTPUT RATINGS
  • Total Max Power: 600W
RMS POWER RATINGS
  • Per Channel into 4ohms (≤1%THD+N): 4 x 50W
  • Per Channel into 2ohms (≤1%THD+N): 4 x 70W
  • Bridged into 4ohms (≤1%THD+N): 2 x 130W
SOUND TUNING
  • Crossover Frequency (Variable, OFF/LPF/HPF Selectable)
    1/2 Ch: LP/HP: 50Hz – 500Hz
    3/4 Ch: LP/HP: 50Hz – 500Hz
  • EQ (Equalizer): Bass EQ Fixed Frequency 45 Hz, Q=0.5, Variable Gain 0dB to +12dB (3/4 Ch only)
DIMENSIONS
  • Footprint: 330 mm x 52 mm x 240 mm
https://www.ebay.com/itm/Alpine-BBX-F1200-4-Channel-Car-Audio-Amplifier-BBXF1200-with-Amp-Kit-BUNDL/113476037122?hash=item1a6bb2ea02:g:YEEAAOSwsqdcHWXm&frcectupt=true
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
560
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
791
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
audiojamonline
CarAudio.com Newbie
audiojamonline
Dragonsyph
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
