Alpine Double Din Touch Screen Acting Funny
  • 2
bigguy2211
I'm asking on behalf of my parents but as I've mention in a earlier post, my parents Hummer H2 was bought used, and the guy they bought it from had a shabby shop put this stereo in this Hummer two or three years ago. Little off story here but I'll get my point across, I was looking for a steering wheel control I could use in my 1986 S10 for the new unit I recently bought, and thank you by the way for recommending I stay far far away from Boss Audio.
I stumbled across, and remember I don't know anything about stereo systems, I do well enough just wiring them and putting them in a vehicle, I stumbled across where you had to have a module to use with an aftermarket unit in order to use the factory steering wheel controls.
Back on topic, my parents H2, you can adjust the volume where you want it, drive down the road several miles and it will turn the volume down, sometimes muting it, mute shows up on the screen. Other times you will have it playing a cd for instance, and it will flip over to USB mode, even when no thumb drive is in the unit but it does this very rarely. The biggest thing I've noticed when I ride with them is the volume adjusting itself, muting or turning itself down but most of the time muting itself.
Could this possible be the steering wheel module thing that I stumbled across? I'm really curious to know. I'd like to try and fix it for them if I knew or had somewhere to start.
start by removing the steering wheel module plug (like a headphone jack) from the back of the unit. it's likely that's causing the problem. they may lose steering wheel controls in the interim, but it won't do what it's doing.
also, clean the screen so there isn't residual gunk on it, falsifying button pressing.
regardless of the result of above, re-do the radio installation. solder the connections and protect with heat shrink or 3M Super 33+. when i fix installs (a regular occurrence) my first step is starting over and removing what the previous installer did. i don't trust any connection done by others if i find one that is poor.
after this, feel free to re-install the steering wheel controls. note that button presses are just resistances in series-parallel combinations so poor connections can resemble button presses. again, solder all connections.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
549
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
774
Got my components yesterday and they were well packed. AnthonyO is solid guy to buy/trade with
22
3K
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
bigguy2211
bigguy2211
Nashville, TN
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
