alpine hu keeps blowing fuses
  • 3
mrmex
colorado
Got another stereo problem so i came back here because i always get great advice.
I have a used alpine cda-7892 im putting in my cruiser, it came out of an exact vehicle that i bought. I am using the same harness that it came with just changed a couple wiring for speakers as the past setup was for use with amps, i will be using hu speaker output.
Installed the hu starts up then blows the fuse within a couple seconds. bench tested it with my dc power supply and it powers up fine and stays on fine.
What do i need to check for? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
TIA
I just tried it again to narrower things down, didnt hook up any amps..just harness and antenna. It powered up and when i tried to put it in a cd it took the disc about half way then popped again....please advise
it is probably blowing because the fuse that it has is rated for the OEM HU. That Hu draws more then the OEM does. I had to up my fuse on my truck to not get it to blow. IT may not be that because I actualy had to turn it up to blow the fuse but you OEM HU may jsut have been week. Be careful with uping the fuse rating tough... the wire may not be able to take the amperage.
i noticed the wire harness from my old pioneer had a 10 amp inline fuse but the alpines has a 15a. So i upgraded to a 15a in my vehicles fuse block and so far so good.
Is this common practice to upgrade to fuse a bit for a new HU?
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
567
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
798
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
mrmex
mrmex
colorado
mrmex
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
